Was doing some more wiring on the 424 tonight and found the 4 position rotary light switch to be bad. It didn't turn and click smoothly and did not have or transmit voltage. I had another one on the shelf that was removed from an early 1970s Cub (exactly the same original switch) and hooked it up. It turns and clicks nicely like it should and it was transmitting voltage perfectly when checked with test light.
I hooked up the headlights and installed the front cowl tonight. When tested, The lights all of a sudden came on and went back off. I had them grounded directly to batter and couldn't figure out what it could be. That is when I discovered that the switch I used has a bad connection at the "hot" terminal from the battery. What I mean by a bad connection is that the terminal on the switch must be loose. I played with it, best it back and forth, twisted on it and they came back on. Worked fine after that.
My question: can these style switches be repaired easily? If so how would one do so? My guess would be to solder the terminals down solidly again. ??? I ordered a new one tonight but it's gonna take a week to get here plus it would be nice to fix this one having that the new one was $40 !!! It is similar to the switch in the picture.
