for a new to me 560 - I need hydraulic fluid.
I did the normal "can I use something cheaper" searching, and determined that I better stick with hytran.
Problem is I'd have to drive f-a-r to get some for the weekend.
I hear that New Holland Ambra Mastertran is Hytran-ultra with a New Holland label...
Normally I wouldn't even take the chance, but there IS a new holland dealer that's only far away (as opposed to f-a-r).
The other plus here is that I share equipment with a guy that runs a new holland using the ambra mastertran stuff - and if it really IS the same product, I then
don't have to worry about contaminating each other's tractors by sharing hydraulic equipment.
Thoughts?
Aside from the new holland question - I'm also not clear on what the ultra is in hytran "ultra". I'm assuming it's ok to run that over "normal" hytran?
Thoughts?
