farmall 200 rear seal and front seal repair question
dewy
just got a motor runnin that sat up a while ,front and rear seals leaking bad....when replacing rear, should i put any kind of sealer on all those gaskets ..the ones that scare me the most are the crank shaft retainers,the little side gaskets and little rubber plugs...any tips would be good ,dont want to seperate tractor twice.....thanks .....dewy
also front seal has speedy sleeve ..do you put any sealer between speedy sleeve and pulley...thanks dewy
