Genny wiring
GordoSD
I am finally getting my 350 reassembled after a teardown and restoration I started 2 years ago. The label I put on the wiring ends have disappeared. At the generator there are two posta, F and A.and I have two wires protruding from the harness shield. One is yellow, about a number 10 (.112), the other is blue, about 8 ga (.166). I can't follow them back because the harness is enclosed and not accessible. Which one is field and which is arm?
Heavy wire should be batt volts and goes to the batt term on the reg. Short piece would go from A term on gen to gen term on reg another short piece would go from F term on gen to F term on reg. Your other wire probably goes to L term on reg
