Need Aftermarket Dash Light and Headlight Bulb Part Number
RTR
I am in need of a good part number (aftermarket) for the headlight bulbs (sealed beam) and the tiny little dash light bulb to fit an IH 424 tractor. Mine were either missing or busted up and couldn't get a number off them. I wouldn't think the "IH part number" would help in this case so I'm either buying from Rockauto or the local parts store.
THanks.
Well.....I've figured out that a "par36" style bulb fits the headlight but finding a part number for them has been difficult....one that will show up on Napa's, Oreilly's, or RockAuto's website at least.
Haven't found any info for the tiny little bulb on the dash yet.
PAR36 is a common bulb shape. 4411 is a 12-volt tractor bulb. Tractor Supply or anyone else should have them. The interchange number for the dash bulb should be listed in the parts catalog, probably something common like a number 57.
(quoted from post at 09:14:59 09/01/15) Use the 1895 bulb in place of the 57 as the1895 is a heavy duty bulb and will stand up to vibration way better
Thank you all for the help.
I would also like to offer this thought I had earlier today. Do they make an adequate LED bulb equivalent for the headlights? That would look SHARP and be bright at the same time!
(quoted from post at 07:18:35 09/02/15)
I reckon this will commence another post specifically referring to LED replacements. I'll post later on when I have a moment. Thanks for the help guys.
