belt pulley size
(quoted from post at 19:10:21 08/31/15) what is correct size belt pulley for a super m. mine has a 103/4 inch. looks like it is for an H
Sounds close, go to case IH and look in the parts guide to be sure
I believe that the same selection of pulley diameters were available for both H and M tractors depending on H.P. and belt speed requirements.
Belt pulleys came in different sizes tractor had nothing to do with size it is what you are using on the belt to drive grinder ect.
Lots will have a number on the center casting. 49248DB was standard in the time area of your tractor. 7.5 face and 11 inch diameter. Lots of the pulleys don't measure exact to IH posted size now if ever. If you find a different number post it.
