Hydralics and PTO question
pcp20us
working on a International 564 which is based on the tractors below, and covered by the IH10 manual.
Diesel Models: 350, 350HC, 350 Utility, 400, 400HC, W400, 450, 450HC, W450 Gasoline Models: 300, 300HC, 300 Utility, 350, 350HC, 350 Utility, 400, 400HC, W400, 450, 450HC, W450.
I want to know if the rear 3PL runs off the hydralic tank which is under the gas tank, or if it has a seperate pump somewhere else ( under the seat.
Also i am confused by the hydralic connection hoses than are connected to the housing next to the gear lever in front of the seat and connect to the hydraulics up the front?
Thnaks in advance
That is what I call a German tractor and you are trying to
compare it it USA tractors it has brothers and sisters
(not an orphan) but I only know that you need a different
manual as nothin covered in that one will work on your
tractor, you may possibly find # 203 not sure but it does
have some kin there.
In Australia it is the closest manual that will fit, to give me an idea. This tractor is not a german tractor it was made in geelong australia.
I have been searching the net for weeks and talking to people. Hence i cannot find the right manual, which is why i asked the questions i asked about the hydrauics.
I gotta say answers like . Its the wrong manual, just sh8t me.
Any way thanks
(quoted from post at 16:59:20 08/31/15) Can you post up any pictures?
sure
this is taken from the web.
this is actual tractor.
i shall post more when i can
thanks
