Doing an oil change on this beast for first time. Got all the info I needed, except, what is the torque you use on the pan plug?
also, the replacement copper gasket I got from NAPA fits, but is a solid copper gasket. The one that came out was a hollow crush type copper gasket. Does this matter? Well the solid one work OK? The NAPA guy said it should be fine.
I'm going to drop the pan and re-gasket at the same time. Have the new cork gasket and know the not over-tighten the pan bolts. Light snug with a 1/4" stub ratchet, or about 10 ft-lbs.
