working on a International 564 which is based on the tractors below, and covered by the IH10 manual.
Diesel Models: 350, 350HC, 350 Utility, 400, 400HC, W400, 450, 450HC, W450 Gasoline Models: 300, 300HC, 300 Utility, 350, 350HC, 350 Utility, 400, 400HC, W400, 450, 450HC, W450.
I want to know if the rear 3PL runs off the hydralic tank which is under the gas tank, or if it has a seperate pump somewhere else ( under the seat.
Also i am confused by the hydralic connection hoses than are connected to the housing next to the gear lever in front of the seat and connect to the hydraulics up the front?
Thnaks in advance
Thnaks in advance
