F30 DECAL PLACEMENT
Where do these decals go? Oil level with
arrow, gasoline, air cleaner decal, only
hook to drawbar with all parts assembled?
Tractor is a 1932. Thanks jim.
The oil level decal is technically supposed to go on the air filter. I personally like it better on the oil pan. It makes more sense for folks that don't always operate an F series tractor.
The "dont hook to the drawbar" decal is supposed to be centered on the differential cover.
The gasoline decal is supposed to be on the aux starting tank neck.
The correct police may have more definitive locations but those will work.
Hope that helps. Please post a pic or two when it is completed.
(quoted from post at 12:21:11 08/30/15) Where do these decals go? Oil level with
Jim, if your air filter housing has embossed "oil level" on it throw that oil level sticker, and air cleaner decal in the junk drawer, it has no place on the tractor.If your air cleaner is smooth and not embossed both of them go on the air cleaner. The gasoline sticker goes just under the gas cap on the starter tank.Drawbar decal goes on the differential cover.
(quoted from post at 15:13:44 08/30/15) What part of the air cleaner does the decal
go on?
Centered above the brass id tag on the cup bolt retainer strap. Just above the strap. The oil level decal would then be centered just below the oil line on the oil cup, All three in a stack
