Tranny seals
Chance M
Like a dummy I didn't change my tranny input and lift all out put shaft seals. My lift all is leaking and possibly the tranny seals. It's not bad but they are. So...if I change my liftall seal then I should change the others.
This is a dumb question but....when I pull that lower output seal housing on tranny, all my grease is gonna come pouring out I imagine? Or is it slow enough I can catch it while I prep the housing and get it back on before a lot gets through the bearing?
I'm sure someone has done this with grease in there. I don't wanna drain it, haha. It's brand new grease.
Also, I'm an online purchaser, I don't like going to town running down parts. Ya'll know a good place to find these seals. I looked on eBay and found the liftall seal but not the tranny seals.
Thanks
Chance
Check this site or external link for seals and bearings.
As for the fluids, just drain them into a container and re-use them when done if the fluid is still good and clean.
A very small amount of rear end oil will leak through the bearing when replacing the Lift-All drive seal. If you have Hy-Tran it will leak a bit faster. Put a container underneath & have the new seal & gasket ready to go. Just pour the oil back in later.
