F12 Single Front Wheel
KNBN
New User
I'm hoping the experts here can help me out - I've been a stalker for years but finally have a question a can't find answered in the archives.
We have a F12 with a single front wheel. It currently has a rubber tire with the cast rim but we recently came across a steel wheel for it. Since it has steel on the back we would like to make the change. Do they use the same axle and bearing assembly? If so, do we have to split the cast wheel in order to remove the axle or can it be pushed out?
Thanks for any help or advice you can give!
Which wheel , I show a 7.50x10 tire option and a 6.00x12 option the first is two halves and has to be split the other has a cast hub and I am not sure what it does ,I have never seen one myself.
Pretty sure they are the same 'axle'.Yes,you will need to separate the halves.I think you will be surprised.NO bearings.Just brass bushings!!!
