This is my second post. I have a '42 farmall H. I bought in it '91 . I bought it to work a few hours a year mowing ,plowing ,general work and food plotting for deer at my place in the country. It's a work horse not a show horse. Well the truth is that it has been the most trouble free piece of equipment I own. I have not had to do anything but grease,oil and gas this gem. I grew up with B's A's and G's so tricycles never scared me. Any way this spring the H did not start. No spark. I knew nothing about magneto's except when my uncle had hold a wire,and I learned there was fire in that thing.(note to self) And they either worked or they did not. I had no idea there were points in there,and so I never gapped them. So by the time I figured that out and got to the points there was no gap. So I gapped them. Well it started but faded fast with weak spark, then quit after about 10 minutes of running on 3 cylinders. So I figure I'm going to replace points ,plugs ,rotor,etc. It's past due. . Have not done it yet but going to. So I'm seeing how to static time it on Utube, and I do not hear that sharp snap that should be happening. So that brings to where I am today. The impulse coupling. I can say for sure the springs are worn out or missing on one of the pawls. So I'm seeing $14.00 a piece for the springs on Ebay. Yikes! I'm a practical man. I won't pay $14.00 for a spring when there is a world of springs that cost a dollar that I might be able to get to work.( I'll post anything I can get to work. I know it's got to be out there) I'm in no great hurry. So this brings to my first question. Is the impulse coupling really necessary ,if you only use electric start? I figure I can static time it an ohm meter or light on TDC. I figure I'm going to need the ignition parts no matter what, so I'll deal with that later. Also I'm a bit fuzzy on checking the coil secondary. Is picture below right? If spark is still an issue after I buy the ignition parts ,I might buy a 12 volt coil and condenser and do a work around. Is the impulse coupling a must have? So if some could lend some guidance I'd be grateful.
