purge hydralics
Dennis@mo
Two problems I'v got. 57 350 farmall sounds awful and drags down engine when I use one of the hydrlic levers. I got HY TRAN up to proper level and the filter is clean for the hydraulic oil. Air in line someone suggested. What is proper way to purge air out of the system? Next problem is my 49 M is blowing oil out of air cleaner out on the hood after 30 minutes of running. Can't see any obvious reason for this to be happening.Starts good and runs strong but after a bit you can see this start to happen.Any help is welcomed on either tractor. Thanks in advance
Gene should have you fixed on the 350, now the M IS the oil coming from the crankcase or is it blowing up from the oil filter cup ?
Not really sure. I don't seem to be adding any for the engine. Will have to watch and see exactly it is coming from. What is your thought on either source of oil?
