oldhammerhead
Hello Again
Well I got the hole fixed in the lower casting neck J-B Weld and a piece of 1 1/2"square aluminum.Put radiator back on tractor new gaskets,Filled with water.Lower water inlet gasket leaks, surface of casting neck pitted not real bad.did not use any gasket cement only grease.Would two gaskets make any difference, Also a little drip from top left bolt on radiator,would thread sealer work there. Thanks in Advance Steve.
