Hello,
I was told that I need lead additive in my M or I could possibly do damage and it will also make it run better.
Also I need to run stabil at all times or the ethanol will wreak havoc as well.
I got it tuned out as best I can. Under load it is smooth and lugs beautifully. But just runnin along no load it is not smoothest running. Don't get me wrong, it runs good though.
My main jet is said to be started off at 3 turns out. That is to rich. It runs fair at that setting but it puts out tons of black smoke, even when running at half to 3/4 throttle while my son rides around property. The idle needle makes little difference in how it runs unless I get under 1/2 turn in.
As I was saying, my uncle claims lead additive will let me achieve a smoother running engine. Says I'll never get it run perfect till I use the additive. Your thoughts plz.
Thanks
Chance
Thanks
Chance
