wheel weights
khouse6
posted this once, added better pictures and measurements.
what brand of tractor do you think that these will fit? what model? what are they worth?
weights have a 8 inch inner diameter, 14 inch outer diameter, 11 inch bolt pattern and approximately 2 inches thick.
i do not see any identifying marks, on the weights. ??
cannot get the picture of the other side of weight to load. maybe next time. lol
As I posted in the other post , these fit 140-560 most ih tractors with 6 lug bolts 15 or 16 and 19 inch wheels never tried on any larger tractors .
thanks, if they fit a 140, should fit 130, which is why i wanted them. feller that i bought them from said that they would fit 130 farmall.
The weights will not fit your 130 tractor. You were wrongly informed.
In addition to what has been stated they will fit, they will also fit 706 and 806 Farmall tractors
No they don't fit a 130 unless it has 140 hubs and pressed steel wheels a 130 and a super a would normally use the same weight. The rears however fit a-140 ,24 inch to 24" , the 36" use the same as a c,h,m,and newer.
