wheel weight
khouse6
what brand of tractor would you think that these fit? what model?
A better picture of both sides will help and some measurements. They could be farmall front or oliver rear or moline rear or ford front , I just can't tell in this picture ,maybe my eyes are getting worse.
Picture focus not the best. Not sure could be a rear weight for a Farmall A and others in the series that followed. Any numbers on a weight?
Depending on size it could be front wheel weights for a 460, 560 and some utility tractors. Can't make the shape out good enough to give a firm answer.
The weights on both of my tractors have parts numbers cast into them. Also list a little tape measure information. The two I have also have those half moon cuts on the out side too and are IH. CUBS weigh 150lb and will pinch your fingers big time! Let us know. To me from your picture they look like front weights. Put something in the picture for a size comparison.
o k, here we go again. inside circle diameter is 8 inches; outside circle diameter, is 14 inches; bolt pattern is 11 inches and weights are about 2 inches thick.
For sure they must be front weights and a pretty small tractor. They would be 14 15 or16 inch rim? Maybe 40 pounds of heft? Could not see any numbers so maybe they are pretty old but International was pretty good at marking everything that was cast with a number. They are red though. Someone out there will come through! They are cute.
