Farmall drive assembly
Can anyone tell me where this part goes I know that there is one of these parts on the pto shift lever its a spring with a brass colored object it sits in the two groves of the pto shift lever when shifted from one position to the next. I took apart the belly drive assembly cleaned it and thought I had everything back together and I was just curious if this part went on the lever on the drive assembly to make it spin?
Could you give us a specific model Farmall you are working with. Otherwise there is about 25 models that are called Farmall.
(quoted from post at 23:20:52 08/22/15) Can anyone tell me where this part goes I know that there is one of these parts on the pto shift lever its a spring with a brass colored object it sits in the two groves of the pto shift lever when shifted from one position to the next. I took apart the belly drive assembly cleaned it and thought I had everything back together and I was just curious if this part went on the lever on the drive assembly to make it spin?
That looks like the end plunger that goes to the governor assembly on a Farmall A, B, C, Super A, Super C, 100, 130, 140, 200, 230, and 240 tractors. I actually need one of those myself.
looks like the spring and plunger of a safty valve in the hydralic block under gas tank on the super c and 200 ......dewy
