international 484
baker3
New User
anyone have a wiring diagram for the neutral safety switch ??
right now the tractor will start when I push the clutch in after it started went to push in clutch and the safety switch engaged the starter any help??
I don't think it's the clutch switch-I'd bet the key(or starter button) is sending power to the starter:the clutch switch just completes the circuit.In other words,the clutch switch is ok,the problem is before it.Mark
I agree, the ignition switch (or shorted wires at the ignition switch) would cause that. Or mis-wiring if it began happening after work that included wire removal. Jim
does anyone happen to have a wiring diagram of key switch I want to see if the wiring is correct before I buy a switch ??
Thanks for the replies !!
