I got the 2444 split.now I need help
Stone2.0
New User
A couple of things I need help with.I cant get the
throwout bearing out.manual says bolts and key
have to be removed from shift fork.cant see
them.2cant even see where the trans shaft oil seal
would go.the shaft continues through a hole in the
housing to another compartment?3 And I cant tell if
the rear main leaks.something leaked all
over.someone tried to seal the clutch inspection
cover.thick goo is all over the inside of cover.see
pic.i had flywheel ground,ordered new pressure
plate. Yesterday doesnt sell the single one.now I
want to order the disc,throwout, and pilot bearing
now.but i need to know what leaked!rear main seal
or trans shaft oil seal?help me out?thanks
I am not at all familiar with the 2444, but if it follows the old IH pattern, the bolts holding the keys (thick washers sometimes) are behind the shaft.
Can you get a parts book for this tractor ? They are very helpful in seeing where all the pieces are located.
GReg
