ih 240 hydralics
judesson
New User
I am having trouble with the lift on my 240, it has sat for 2 years and fluid leaked out. I refilled to the bottom of the fill plug and I have cleaned the screen on the right side but still no movement. the back cylinder is leaking a little and sort of foaming and it is fully extended.
any ideas on what to check or do next ?? thanks judesson
Check engine oil , the front seal fails in the hydro pump
and fills the crank case with oil , if it's normal you may
need to run the engine at wide open throttle a minute to
prime the hydro pump .
(quoted from post at 17:14:31 08/18/15) Check engine oil , the front seal fails in the hydro pump
thanks , I will give that a try Judesson
