Correct Carburetor Kit for Model A, Engine C-123
Sourbone
New User
It looks like the carburetor on my Farmall Model A needs a rebuild. The bowl seems to fill intermittently running for awhile and then the fuel is not filling the bowl. No flow when taking out the plug at the bottom This last time I ran it. Which rebuild kit would be the correct one for this carburetor. The engine block in labeled C-123? Thanks for any help.
Engine numbers do you nothing as for what carb kit you need. You need to get the number off the brass tag that should be on the carb to get the correct kit for it.
