Hi guys!
Just finishing the restoration on my 1930 Farmall Regular and I am having a hard time getting it to run right. It starts up just fine with only two cranks but for every adjustment of the throttle I need to adjust the choke. At idle the choke needs to be nearly completely close for it to run but if I open the throttle up anywhere between half and full it still needs about half choke and will occasionally backfire and stall.
The carburetor was completely rebuilt by a professional carburetor shop nearby and it is the IH model "R", 3 piece brass carburetor. The only thing I don't know is if the carburetor was adjusted to its factory settings.
Does anyone here know what the factory settings are and which adjustments are which?
The only thing I thought might make a difference is the air hose is not on yet except it ran just fine before the rebuild without it. It does run a bit rough now too at idle which is why I think its more of an adjustment issue than the air hose not being on.
Also, the throttle lever and magneto lever are rusted together. Does anyone have any experience on getting them apart or is there anywhere that makes new ones?
Thanks to all who reply!!
FarmallCT
FarmallCT
