Tractor Breaker
New User
I bought a M from a man that he bought to restore and gave up on! What I am having a problem with is it does not have any wires hooked any where. The generator is in a box the amp meter gauge is in the panel not hooked up. The on off switch has 2 wires cut off hanging on it. I have a new Harness loom that has a big Blue wire a Yellow wire and a small Black wire in it taped to the gas line and Temp gauge. I have a Voltage Regulator in a box that has 3 side post stamped from left to right L, BAT, F, and then there is one on the underside, what or where do they hook to? The Tractor has a Magneto on it with a broken choke cable hanging on the side of it! The starter has a cable on top lug that goes to the push button switch, and a ground cable fasten to the starter mount bolt and a + battery cable that goes to the push starter button switch! How do I hook it all together to make it charge and shut off? Thanks!
