farmall 200 hydralic block surging
dewy
installed used block.right side rockshaft surges or jumps ,when all the way raised,pull it back to driver and stops jumping..only on right side...any ideas .......thanks dewy
Maybe over extending the hydraulic cylinder stroke ? Or maybe it is junk ? I think you need that pressure gauge we talked about yesterday , then I would know the valves are working correctly.
