My brother has a WD 6 that we recently swapped the engine on with a TD 6. He says he has it running fine on gas, but when he switches to diesel he can't get any fuel flow
into the injectors. The transfer pump seems to be working OK because when he cracks the line going from the transfer pump to the main pump he has pressure and fuel. I
told him to remove the lines at the pump and pour the towers full of diesel to see if that helps. He told me that the fuel he poured on top of the towers doesn't even
bubble when he does that.
Any suggestions as to what may be wrong with it?
Thanks in advance.
BTW, He is currently on a business trip and that is why I am writing this post.
Thanks in advance.
