Need help on these fast hitch adapters
LSGUNSS
Will these work on my Farmall 460? I called and asked and the guy on the phone wasn't sure. I didn't know if anyone bought and used these or not. Thanks in advance.
https://www.external_link.com/Fasthitch-to-3-Point-Quick-Attach-Prongs-Interna-p/111429.htm
The link does not work..
However, the "large" fasthitch prongs will fit all fasthitch equipped tractors from the 300/350/460 to the 400/450/560 up to whatever was the largest tractor equipped with a fasthitch.
The "small" prongs were used on Super C, 200, 230 etc.
I'll try the link again. https://www.external_link.com/Fasthitch-to-3-Point-Quick-Attach-Prongs-Interna-p/111429.htm
It doesn't say what size they are just says they are cat2. That should be the large size fast hitch I would assume but you know how that goes
Maybe i should go back into production on the fast hitch to three point adapters that i use to build for guys , they were strong enough to pull a five bottom semi mount plow and they were adjustable for both Cat 1 and cat 2 three point . The down side is that they would not be cheap as the bar stock was a special order and i had to take 160 feet at a time .
504 that is exactly like the ones I was looking at only the ones you posted are $5 cheaper. THANKS!! I'm on the phone now with them.
