I bought this Regular cheap for parts and for the
OD gearbox on it, assuming it will go on my
F20. Will it? Not a big deal if it won't. Which
manufacturer is this one made by, Heisler? How
do I get it off the front of the trans? I lightly pried
on the yoke but it didn't move and I didn't want
to break anything. Do I need to use a puller to
remove the yoke so I can get the cover off,
under which I'm assuming are the bolts holding
it to the front of the transmission? Or is the
shaft the yoke is mounted on somehow
retained by the front cover? Lastly, how to use
it? Can you use it in any gear to bump that gear
up, or only "high" gear? Never knew anyone that
had an F series around here with this apparatus
on it, but I think it's neat. Thanks !
Ross
Ross
