Took off L rear axle on B
Farmallb
Didn't notice it when it fell, but later noticed a 3in by around 1/4in pin laying on the ground. Its shiny. Where does it go to?
"axle" or diff shaft from the tranny to the final drive. If you removed the diff shaft housing that pin goes in a hole and thru the brake band there is no pin where the axle is located
