I printed out the #4 wiring diagram, from a Post by Jim, with a link to Bob's Wiring Diagrams. The one difference that I have is that I have a three post regulator, instead of the two post cutout.
I assume that I still connect the F terminals to one another.
That the A terminal should go to the gen. terminal on the regulator.
In Bobs diagram he has the ammeter getting the power from the battery and then going to the BAT. terminal of the cut out. Would that wire go to the BAT. terminal of the regulator instead of the cutout?
I do have lights to wire and so I assume the rest of the diagram is going to be exactly what I need.
Thank you
Steve
Thank you
Steve
