Rebuild kit hydraulic pump IH350D utility
RAMJR1
New User
I need a rebuild kit for a hydraulic pump for my Dad's 350D utility IH tractor. If someone has one that has been rebuilt in good condition I could use that. If anyone knows which direction to point me in for this I would appreciate it.
They are considered non-rebuildable. The only possible fixing is to replace the bushings and have them reamed concentric to the original bores. the shafts are probably worn and cannot be resized. If the gear teeth have touched the housing, it it toast. Seals and some end frame components might be available, but they will not really fix it. Good used, or new is the reality. Jim
