Looking for Farmall H distributor
PretendFarmer
I recently inherited a 1944 Farmall H, straight off the tobacco fields from my aunt. They needed to keep the magneto for another tractor, and I'm certainly not going to complain about that. So with that said, if anyone has a scrap H sitting around, and they would be willing to sell me the distributor I would appreciate it. As this was a mag tractor, I'll need the distributor mounting housing as well. Thanks...
You'll find it easy to find a distributor for an H. Since mine is a '39, I replaced the distributor with a mag to be more "original". So, I've still got the
old Dist. I can part with it after about ten years of it sitting around. Kelly
Lower lumbar support is one of the best things you can add to an H, and you already got it. Congrat.s
(quoted from post at 15:20:19 07/30/15) You'll find it easy to find a distributor for an H. Since mine is a '39, I replaced the distributor with a mag to be more "original". So, I've still got the
What would you want for it shipped to 06096?
Pretend, please look up shipping from 78130. That plus an Andrew Jackson should cover my troubles. My email is
<[email protected]>. Kelly I'm glad you're saving the old H. Mine is a '39 with a four digit serial number made on the last day of
the first full month of production. I use it almost daily.
(quoted from post at 15:24:59 07/31/15) Pretend, please look up shipping from 78130. That plus an Andrew Jackson should cover my troubles. My email is
&lt;[email protected]&gt;. Kelly I'm glad you're saving the old H. Mine is a '39 with a four digit serial number made on the last day of
I send an email. Turns out the H is a distillate model. I haven't taken the valve cover off to see if it still has the distillate head or not. Its going to be used for lite work so it doesn't really matter. But if I ever end up pulling with it, I'll have to have the head redone.
