Do you install pads under the radiator-F20
SDE
I have not seen any pads for this tractor, but then again, when I got it, it was in pieces. So should there be pads between the radiator and the frame?
Thank you
SDE,
(quoted from post at 13:59:55 07/27/15) I have not seen any pads for this tractor, but then again, when I got it, it was in pieces. So should there be pads between the radiator and the frame?
Thank you
SDE,
No pads, bolts direct to the frame rails. no flimsy brass tanks on these old girls, just heavy cast iron, no need for pads.
Thank you. I put the front wheels under her last night and removed the jack and blocks from below the radiator area. I can now put those bolts in. She is starting to look like a tractor again.
SDE
The only thing between the radiator and the frame is the dust shield.
I don't think mine have anything but the dust shield , but if you needed to move the radiator up a bit to make the hoses line up better you could put something in there , otherwise not really needed.
