Bryce Frazier
Hey guys. Been using my H more and more, finding it to be a step better than the Super C (imagine that right???).
Anyways, when I first got this thing, I was discing with it. When I turned around at the end of the field, I was then going down hill, and the engine would rev way up (before I could slow the throttle down). WHEN it hit a high RPM, there would all of a sudden be a weird vibration in the rear end of the tractor. I could feel it in my boots/feet, kind of hear it, etc.
I finally realized that it wouldn't do it if I pushed the clutch in, then started moving again, however it might start doing it again in 5 feet, or 50 feet, or the next day.
Next, I realized that it was the PTO shaft that was doing this, not actually turning, but vibration, something fierce too!!
So, I solved the problem by just leaving the pto shaft engaged... Well, that worked out just great, until I needed the PTO for the baler and swather.
Problem was worse now, thee pto shaft was shaking/vibrating/and trying to turn, with full engine power behind it, not like when the oil just moves them a little. Had to shut the tractor off when hooking up PTO stuff, otherwise, I couldn't get the yolk to slide onto the shaft.
Now it sits there and vibrates the SNOT out of the implement that is hook up, until I either push the clutch, or turn the PTO on?
So, something is worn out, and I am guessing, not fully disengaging, so, where do I start??
Bryce
Bryce
