More on the A-16 sickle mower
old
So the nut is suppose to be left hand tread so I tried to take it off but all it does is spins and does not loosen up. Does not matter which way I turn it, it is ano go. So how do I take thing thing apart so I can either replace the bad parts or weld it up in such a way to fix it??
Thanks
If the shaft the nut is on does not turn when the nut is turned, split it, it is worthless. putting it back together might br possible with some ideas, but get it apart first. Jim
