Need help finding Hyd. pump Oil Seal
RTR
I have this hydraulic pump with an oil seal for the shaft. Pump wasn't working so I thought I'd put a new seal in and a wear sleeve on the shaft since it has a groove. How can I find a "good" part number for this seal ? It is a National 481466 SSR and that is no help when searching parts sites.
Do you have an O'Reilly's auto parts store close by. If you do they should be able to cross that number over and get you the seal. If you do not send me an e-mail and I'll call the one I have and get you the number. Include the number of the old seal
Dunno what the issue is... 481466 appears to still be a good National number. Timken uses the same number. They are even used in Ford and Jeep transfer cases as shifter shaft seals!
6903 SKF
385038R91 at the CIH dealer.
(quoted from post at 02:50:40 07/27/15) Dunno what the issue is... 481466 appears to still be a good National number. Timken uses the same number. They are even used in Ford and Jeep transfer cases as shifter shaft seals!
6903 SKF
Thank you. I tried searching it in RockAuto.com and Napa site to no avail. Looks like they are in fact used in a Ford Transfer Case. I found the seal by searching Nationals website, then looking at alternate part numbers then searching those on the RockAuto site. They've got 12 left at $1.34 each!! I think I'll buy them all so the next pump I do I'll have a seal on hand. Never know when someone will call wanting a seal too.
As for the wear sleeve (speedi-sleeve) that goes with it, it is also listed under the same Ford Bronco listing on RockAuto for about $20.00. I presume this sleeve will work on the IH Hyd. Pump.
