I have a 450 in the shop. it has a behlen power steering unit under the hood that was leaking oil around the steering shaft. I noticed driving the tractor in the shop that the power steering wasn't working. anyways I resealed the unit and replaced back on the tractor. I hooked a test gauge on the pressure hose that feeds the unit with oil. the gauge only reads 150psi. I then put a gauge in the rear hyd outlet on the tractor and read 1000psi. I do have a shop manual but cannot find it. how much psi should be feedind the powersteering unit? im sure it should be more than 150psi. the hose with the 90 degree bend is where the oil pressure is coming from to the unit. could something be wrong in that hyd block?
<image src="http://forums.yesterdaystractors.com/photos/mvphoto24999.jpg"/>
<image src="http://forums.yesterdaystractors.com/photos/mvphoto25000.jpg"/>
