Sonny in Mn
I am trying to help a friend with his 544 Farmall. It appears to be running rich & making lots of black smoke. I removed the hose to the air cleaner & it makes no difference. Choke is open. I tried the mixture screw it runs the same as long as it's slightly open to wide open. I would like to check the float level but I don't know what it should be. I should add that my friend doesn't have a book on this tractor & isn't planning to get one. The manifold has been welded & it could be a problem also, but I would expect it to act lean rather than rich. Thanks in advance for any advice. Sonny
