Need a part for an A-6 sickle bar mower
old
Ok so the bear end of the pitman has broken and I am in need of this part. Anybody have one laying around by chance??
Thanks.
Oh by the way I think that is the model of it but if not it is the mounted sickle bar mower with hand lift for the Farmall A
No picture at this time. Do not have a clue about the mounted mowers on the H or M. This is the bearing end of the pitman and has the bearing in the center and a metal plate tab that comes off and the pitman bolt to it and the tab part has broken and I have welded it back on so many times there more weld then tab
Rich,
Sounds like a A-16
The parts book call it a Pitman Box ( complete assembly) part # MB 32936.
I can't say for SURE, but believe the same part off a A 21 or a 27 v will work.
Some had bearings, earlier ones had bushings.
This one has a greaseable bearing on it. Not sure how it all comes apart since I have not been able to get the nut to come off as of yet.
I'm pretty sure I know what you're talking about. I would verify with a picture but for some reason it won't upload.
The nut you're referring to is the retaining nut I'm guessing? It looks like a castle nut but its not, just left hand thread. After the nut is off I used a puller to pull the whole assembly, then disassembled it from there.
If the assembly is the same as a 27V CaseIH carries all the piece that go in it, they are just pricey. Last time I was quoted a new bearing was $140, new retaining washer was a little over $100 a piece, and the felt seal are about $5 for a pack of 5.
Hope this helps.
When mine came off my #27, I took the remains to a bearing business, and they matched me up with one that worked.
Ya sounds like what I am needed. The bearing and all are good but the plate part that bolts to the pitman stick is what is broken. Sp far I have not been able to get that nut to come off. If I can get it off I can then make a new plate part and put it back in service
On this machine the bearing and all are still good it is the pitman stick plate that is broken off
