Hello Everyone,
Just purchased a MD Farmall and believe something is wrong with the clutch. We pull started it and when it started when pushing the clutch
in the tractor kept going idled it down and the gears ground but got it into neutral. When pushing in the clutch to shift gears all it does
is grind the gears and won't go into gear. I assume something is wrong like pressure plate? Any other ideas?
