Farmall MD engine swap
Hello guys, I'm new here, and I'm looking to get some pointers and advice on an engine swap that I'm about to do in my Farmall MD. I'm looking to put a D-281 engine in it, while I'm at it, I'd like to replace the clutch. My question is, do I purchase a clutch for an MD, or one that fits a Farmall 450? Also any other tricks of the trade while doing the swap would be appreciated.
Thank you!
Chad
Unless you have a real late MD and want to keep the liftall unit you use the MD flywheel and 11 inch clutch. If the D-281 has the flywheel and you have a late liftall or none use a SM 12 inch clutch. Need to run fuel lives different and the D-281 from a tractor won't have the friction parts for the throttle position. Choke may be a little different depending on carburetors but no problem. Tractor D-281 manifold has different electrical switch than a MD. MD grounds in diesel mode and a D-281 is open in diesel mode and closed in gas mode.
(quoted from post at 14:29:27 07/10/15) Unless you have a real late MD and want to keep the liftall unit you use the MD flywheel and 11 inch clutch. If the D-281 has the flywheel and you have a late liftall or none use a SM 12 inch clutch. Need to run fuel lives different and the D-281 from a tractor won't have the friction parts for the throttle position. Choke may be a little different depending on carburetors but no problem. Tractor D-281 manifold has different electrical switch than a MD. MD grounds in diesel mode and a D-281 is open in diesel mode and closed in gas mode.
Can I use the friction parts for the throttle, and the fuel lines from the old D-248 engine that was in the tractor? I'm not sure what you mean by lift all unit. Are you talking about the hitch?
(quoted from post at 14:35:20 07/10/15)
The lift-all is the hydraulic pump assembly.
(quoted from post at 15:54:28 07/10/15)
Ok, yes, I will keep the lift all on it. Mine is a 1947 model. Do you think it will be a problem with the throttle? Can I put it back the way it was on the original engine and it work fine? Or will I have to modify it? Also, do you have any tips on the engine installation to make the process go smooth? I've never done one of these, and I don't want to mess it up lol
Yes you can change the parts over to use the MD type throttle. Best to get a manual because you have to change parts at the cross shaft going from left to right side of the engine. Adjustments will be needed and a manual will give what needs adjusted or set. If no parts were changed in the past the D281 has a injection pump with only two lines to the primary pump on rear of injection pump. MD was equipped with a primary pump and scavenging pump combined with 3 lines. Need to tie the return to tank where the D281 was at pump. IH made parts, fuel line or lines was part of them, to change MD tractors to B type pumps so there is a chance your MD was changed in the past.
Jim, I'm changing engines because the one that's in it is seized up, and I can't find another 248 engine. I've run across a 281 that's fairly reasonable.
Thank you for the info. I'll be sure to ask for assistance on here as I'm installing the engine. I'm sure I'll run into a few snags.
The 12 inch clutch is desirable. as is live hydraulics. The newer engine should have a live hydraulic pump. The 12 inch clutch and flywheel will not fit using the older Liftall pump. Using the liftall space for a hand fabricated reservoir, or using a reservoir from a later tractor with Live hydro will work. Jim
Be sure to keep original engine. If you ever
sell tractor include it in case someone
wants to restore it and use original engine.
A heavy duty PP is needed to accept the added torque. In my opinion semi metallic (not ceramic) driven disks will provide good holding power as well as life in rough service. Ceramicis too jerkry and wears the metal of the FW and PP dramatically. Jim
(quoted from post at 06:48:35 07/11/15) A heavy duty PP is needed to accept the added torque. In my opinion semi metallic (not ceramic) driven disks will provide good holding power as well as life in rough service. Ceramicis too jerkry and wears the metal of the FW and PP dramatically. Jim
Where would be the best place to get one? And is there a certain one in particular that you recommend?
(quoted from post at 05:59:42 07/11/15) Be sure to keep original engine. If you ever
The tractor will never be sold, it was my grandpa's.
(quoted from post at 11:39:46 07/11/15)
Then keep it for yourself or if you want the correct engine....
That's what I'm going to do, it's going to cost way more to rebuild that engine than to buy a good running engine to swap out. I've tried for over 4 months to get the original engine to break loose without any luck. I just hope this will be a fairly easy swap.
Some claim to be Heavy duty, But contacting a rebuilder or supplier might get a more robust clutch.. Getting a Super M Liftall and a 12 inch clutch is best Jim
I'm having a time finding a super M liftall Jim. I found a guy that has been building IH clutches for years, as long as he builds a heavy duty 11" clutch, do you think it will be ok?
Probably be okay with a good clutch. Some have run hopped up M tractors with 11 inch clutches making more power than the D281 will.
Externally the MD and D281 block is the same size. You could use the MD fuel pump or other parts on the D-281 if wanted. May need to adjust the fuel pump setting for best results if used with 281 injectors. Line hookup to pump is different on some though. One thing to look out for is the ignition drive housing bolt patterns could be different. Pretty sure it was later than your tractor when the bolt pattern was changed to be the same as a D-281. If going to use ignition without a engine driven hydraulic pump you need a housing to fit the D-281. Also the MD injection pump was vented to the intake pipe and the 450 pump wasn't.
(quoted from post at 18:18:40 07/12/15) Probably be okay with a good clutch. Some have run hopped up M tractors with 11 inch clutches making more power than the D281 will.
I'm getting the complete engine, so I plan on installing it without using any parts from the MD, with the exception of the clutch and flywheel and throttle. So I'm hoping that works. I guess I'll just block off the hydraulic pump on the 281 engine.
Thank all of you for your input, I'm sure I'll have other questions when I actually get the engine here, and get started. I wished I could've found a good running D248 engine for sale, but I'm sure using a 281 engine will not be too hard of a swap.
Do not block it off, put a loop hose intake to pressure, and fill with Hytran.. Failure to do this will result in pump failure and that is not good. Jim
(quoted from post at 19:37:05 07/12/15) You could remove it ?
Again I'm new at this, if I can remove it, I'd rather do that. If I remove it, will the distributor bolt back up, and everything can be timed correctly?
Hey guys, I thought I'd let you all know that I've located a guy that can get me a 12 inch clutch that he says will clear the belly pump.
Be sure to rig up for heavy lifting and be safe. I just hauled a TD-6 engine for my brother to install in his WD-6. The engine alone weighed 1700#.
I figured the engine would be heavy, but I never dreamed that thing would be that heavy. I'll probably use my loader tractor to lift the engine to install it, because I don't have any hoists that will support a load that heavy.
No, you need to find a MD distributor drive housing and gear. There are illustrations of what you need in the on line parts manual. *which caseih.com has improved a great deal. Jim
Again Jim, you are a lifesaver. I found one on link_disallowed, part # IHS3112, only problem is, it fits several models including the MD, will you look at this please, and tell me if this is what I need?
You need the housing with gear that replaces the hydraulic pump. Used on models without engine mounted hydraulic pumps. Bolts to the front cover with 4 bolts and has a two bolt flange on rear to mount a distributor or magneto. Probably have to find used. Used on later MD tractors, SMD, SWD6 and any D-264 or D-281 without a engine mounted hydraulic pump. Housing will have number 261206R1 on it and started on MD tractors with engine # 19282 and higher.
Your MD will have the housing between the magneto and the front cover but have # 8224 D or DA and a different bolt pattern to front cover than the D-281.
