The shut-off valve on the original was leaking. The valve on new aftermarket sediment bowl assemblies is not compatible with the seat on IH originals so I changed out the entire original sediment bowl assembly with a new aftermarket one. It worked fine for a few days then began to leak around the bowl seat. I applied some sealer around the lip of the bowl. It's a neat job - no sealer anywhere but around the bowl lip. Without the bowl in place the gas runs out just fine. With the sealed bow held in place, the gas runs out just fine. But, a little upward, hand pressure on the bowl will slow the gas-flow to a trickle. Tightening the bail will cause it to slow down a little more. The filter screen does not block the slots where the gas should flow out of. I have another new gasket and filter screen. Assembled with them, without sealer, the same fuel flow problem occurs.
