i rechecked the valves; all are opening and closing when the valve is open there is some slop
checked the compression tester on my SC Charlie and it is working
so here's the plan:
taking the head to the shop monday, gonna replace valve train assemble, rings and rod bearings.
question: can a head bolt hole be drilled out. one of the head bolt holes in the block has been retapped to 1/2"-13 NC can the hole in the head be drilled to match.
any other options are welcome!
bass
53superC
so here's the plan:
bass
53superC
