My 460 is running kinda rough and I have to choke it to start even when it's warmed up, it has......
New intake/exhaust manifold gasket (tested again, no leaks)
New plugs
Carb cleaned and kit put in it.
Main jet 7 turns out.
Idle mixture screw does nothing when I turn it in or out (could be part of the problem)
Tried to adjust timing no improvement.
Try to run in taller gear, she sputters and try's to die. Really have to feather the clutch.
Any advice appreciated, thanks.
New plugs
