seems like every one i see has the front of the block broken where it bolts on to bolster. or the bolster is broken.....thought i had
agood one and went to take off bolster and when i unbolted bottom left bolt a chunck of the block fell off..man if i put it back on by
hand you cant even see the crack...the hole bottom corner of block just fell off that is depressing.......what causes so many broken
blocks....also can it be fixed or trash it.....i will try to get pic.....thanks always ......dewy
