Farmall c head
Jefutty
New User
I have a farm all c that I put a 140 engine in and the head won't line up with the radiator. So I was going to use a super c head but I wanted to check with you guys first to.see if there was a head I could get more power out of the would work with the farm all set parts
Use the 140 or 240 radiator , there are others 424 I also think will fit if it had the gas engine. If unavailable cut the neck at the top of the radiator and adjust to line up with what you have.
If you mean the outlet to the radiator either cut it off or use the one on your C head provided the bolt pattern is the same. You can't use a 140 or SC radiator because they are taller than the one on the C. If you use a SC grill you have to raise the hood and gas tank.
