Hi, I recently bought a Super C and it started fine the first half dozen times I mowed with it. The amperage gauge doesn't work. Today it wouldn't turn over. I bought a new 6V battery and amperage gauge. The first thing I notice is as soon as I pull out the switch the new gauge reads a 3 amp draw with nothing running yet. Normal? The tractor started right up and I noticed no amp charge while running, but the lights would pull up to 10 amps drain. So I put my DVOM on the battery and not running it reads 6.3Vdc. Running at low idle it reads 7.7Vdc and high idle it reads 9.5Vdc, but no amperage charge.
I'm assuming this tells me the generator is charging, but the regulator isn't regulating?
Thanks for any help,
Dan
Dan
