jamarino28
New User
I have picked up my first tractor to help out with general property maintenance. International 300 Utility, Upon the first day of operation I immediately noticed the lever that controls the PTO is out of adjustment (assuming) this is a correct assumption.
[u:6b370d77ec][b:6b370d77ec]Part 1.[/b:6b370d77ec][/u:6b370d77ec]
The problem is that when starting tractor PTO kicks on even when lever has been pressed down in the off position. Even after pushing in clutch, depressing lever, and releasing clutch the PTO will self engage itself on its own when the tractor is moving.
Is this the correct assumption to be making that the PTO lever needs to be adjusted?
[u:6b370d77ec][b:6b370d77ec]Part 2[/b:6b370d77ec][/u:6b370d77ec]
Just recently after cutting about 5 acres of grass I stored the deck mower and tractor for 2 weeks (never correcting part 1's problem). Came back to cut some more grass. Still had the same issues with PTO wanting to self engage/ not stay off. If anything the problem was worse. On top of that now there was a loud whining and clunk noise. When mower was put under load "full width of deck taking grass" PTO would bog down to a crawl. After shutting down tractor i could hear what seemed to be a boiling sound coming from the housing around the PTO shaft, and the housing itself was extremely hot.
Tractor still starts and I can engage and disengage PTO with lever. Whines when PTO is engaged and also when it is disengaged. Extremely hot housing, and bogs down under load. I did not have these issues when operating deck 2 weeks ago.
Any ideas on what can do or has someone had a similar problem that can point me in a direction to start tackling this issue. I am new to operating this machine but have done work on many other pieces just not evolving PTO's.
Thank you for your time hope everyone has a great 4th of July
Semper Fi [/u]
Semper Fi [/u]
