F-12 exhaust
Built an exhaust pipe and turn out for my -12. Tried to make it resemble my F-20 turn out. Tell me what you think.
click for you tube video of it running
-Jeff
(quoted from post at 19:13:18 07/01/15) HOLY COW!! That is GOOD! 8) How did you do it?
Thanks Kirk,
I used 1-1/4" black iron for the exhaust pipe, I cut down a round 1-1/4" closet flange to match the manifold flange. The pipe bends I free handed the notches with a portaband and tried to match the angle of what I took off. The turn out is a 90* and a coupler welded together, I ground the weld smooth then cut the angle out. I put a bead of weld around the lip then ground and filed till I was happy with it.
I should have taken photos of the process
-Jeff
Pipe looks good. I still have a Kerosene manifold for mine, welded up an exhaust pipe from stainless for it. Got a matching 3" stainless stack for my F30.
